September 27, 2017 | 17:00
Publisher: Futuremark
3DMark Time Spy, meanwhile, is a DirectX 12 benchmark that runs at 1440p. It is designed to properly utilise the advantages of the DirectX 12 API. The benchmark is available for free, but you'll need to pay to change any of the settings, including the resolution. We use the default settings, so you should easily be able to compare your score.
VRMark is another synthetic GPU benchmark from Futuremark, this time specifically designed to assess a system's ability to handle VR gaming, although no VR headset is required. The Orange Room test assesses whether a system is capable of meeting the current minimum requirements for an Oculus Rift or HTC Vive VR headset. We run it at default settings, so users can easily compare scores here to the free version of this benchmark where settings cannot be changed.
